SDTN
May 06, 2024Aspirant
NightHawk CM2000 leds burnt out
my nighthawk CM2000 modem , looks to have the power led and the globe internet led burnt out can they be replaced. Everything seem to be working ok. the upstream and downstream led ar lit as is the m...
SDTN
Thanks for a quick reply. The modem is out of warranty by 1 month. Just my luck.
May 07, 2024Guru - Experienced User
I probably wouldn't mess with it if its still working. Soldering in new led's just puts you at risk for frying something.
If you can still log in and see everything through the gui, thats what I'd use.
And if you're at -17dbmv on the download power, you need to check your line. Thats way to low and out of spec.
