Zaphod-17
Jul 04, 2024Tutor
Nighthawk CM2000, RAXE300, pfSense CE, XS712Tv2 12-Port 10G Managed Switch Setup
A brief recap: Have used a pfSense virtual machine router/firewall for over a decade. A switch to Spectrum 1Gig Ethernet 2yrs ago forced a double NAT situation as could never succeed in coupling Spec...
- Jul 06, 2024
O mio remorso! I apologize profusely to all. What ocean is deep enough to hide my tears of shame?
Every step has been a mistake: pfSense is Netgate, not Netgear!
The premise for every action taken over the past month was thus sorely flawed.
Your good graces have been abused. And oh! Netgear tech admonished for never having heard of pfSense; Spectrum tech urged into the crawlspace with a weed whacker, to each unjust.
Fare well! and if for ever, still for ever, fare thee well!
Jul 04, 2024Guru - Experienced User
Please post a copy and paste of the modems connection status page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Zaphod-17
Jul 04, 2024Tutor
Had gone over the post length limit so had to delete. This is from the new CM2000 that arrived this morning. Connection Page:
Startup Procedure | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Downstream Bonded Channels | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Upstream Bonded Channels | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Downstream OFDM Channels | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Upstream OFDMA Channels | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Extended Upstream Transmit Power | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Current System Time:Thu Jul 04 14:30:30 2024 | |
System Up Time:02:27:04 | |
- Zaphod-17Jul 04, 2024Tutor
New CM2000 Event Log:
Time
Priority
Description
Thu Jul 04 12:04:09 2024
(Notice (6))
DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2.;CM-MAC=e0:46:ee:8f:b8:6b;CMTS-MAC=00:01:5c:8f:98:68;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 04 12:04:04 2024
(Notice (6))
TLV-11 - unrecognized OID;CM-MAC=e0:46:ee:8f:b8:6b;CMTS-MAC=00:01:5c:8f:98:68;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 04 12:04:03 2024
(Error (4))
Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=e0:46:ee:8f:b8:6b;CMTS-MAC=00:01:5c:8f:98:68;CM-QOS=1.1;CM-VER=3.1;
(Error (4))
Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=e0:46:ee:8f:b8:6b;CMTS-MAC=00:01:5c:8f:98:68;CM-QOS=1.1;CM-VER=3.1;
Time Not Established
(Notice (6))
Overriding MDD IP initialization parameters; IP provisioning mode = IPv6
(Critical (3))
SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:8f:b8:6b;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 04 11:42:06 2024
(Notice (6))
Thu Jul 04 11:42:01 2024
(Notice (6))
Thu Jul 04 11:42:00 2024
(Error (4))
(Error (4))
(Notice (6))
(Critical (3))
Thu Jul 04 11:10:23 2024
(Notice (6))
Thu Jul 04 11:10:18 2024
(Notice (6))
(Error (4))
(Error (4))
(Notice (6))
(Critical (3))
Thu Jul 04 10:06:01 2024
(Notice (6))
Thu Jul 04 10:05:56 2024
(Notice (6))
Thu Jul 04 10:05:55 2024
(Error (4))
(Error (4))
(Notice (6))
(Critical (3))
Thu Jul 04 09:54:31 2024
(Notice (6))
Thu Jul 04 09:54:26 2024
(Notice (6))
Thu Jul 04 09:54:25 2024
(Error (4))
(Error (4))
(Notice (6))
(Critical (3))
Thu Jul 04 08:58:15 2024
(Notice (6))
Thu Jul 04 08:58:10 2024
(Notice (6))
(Error (4))
(Error (4))
(Notice (6))
(Critical (3))
Thu Jul 04 08:01:38 2024
(Notice (6))
DHCP Renew - lease parameters Time Protocol Servers modified;CM-MAC=e0:46:ee:8f:b8:6b;CMTS-MAC=00:01:5c:8f:98:68;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 04 07:51:53 2024
(Notice (6))
Thu Jul 04 07:51:48 2024
(Notice (6))
Thu Jul 04 07:51:47 2024
(Error (4))
