db3058
Sep 26, 2023Guide
Nighthawk CM2050V Comcast Firmware Killed Speed
I understand Comcast has just updated the firmware in these routers from V2.01.03 to V9.01.01. My download speed went from 934 to 225. Comcast tech came out yesterday and cleared some signal loss b...
- Oct 24, 2023
I contacted a supervisor who actually responded he could see the modem was not properly provisioned, he opened another ticket and one of their best techs came out. I think they fixed it from inside but he was excellent. Problem solved after a month and about 15 tickets opened. Thanks for the encouragement
Oct 11, 2023Guru - Experienced User
This ISP has been working with something call mid-split. Might ask them about this. IF it was working at one point then not, ISP has done something.
db3058
Oct 11, 2023Guide
The tech who came out here knew his s**t....he was awesome. The bottom line is I'm getting 1500 mhz into the modem and 200 out. It's a piece of junk. I worked outside plant with ATT for 7 years and 30 years as a PBX tech with thousands of circuits. I'm a commercial electrician as well. I know many times regardless of diagnostics, stuff needs to be replaced.
- KitsapOct 11, 2023Master
db3058 wrote:The tech who came out here knew his s**t....he was awesome. The bottom line is I'm getting 1500 mhz into the modem and 200 out. It's a piece of junk. I worked outside plant with ATT for 7 years and 30 years as a PBX tech with thousands of circuits. I'm a commercial electrician as well. I know many times regardless of diagnostics, stuff needs to be replaced.
Hardware fails. It is a fact of life. It is also a fact of life firmware updates have errors. It would not hurt to request Comcast to push the firmware update to your modem again.
- db3058Oct 11, 2023Guide
Do you work for Netgear?...your responses do not make sense. There are thousands upon thousands of reviews on the net indicating the modem is junk...I'm the fool who had hope. I'm the fool who spent 325 bucks on a piece of junk. I'm pissed. It's despicable that Netgear puts out this garbage with so many negative reviews and people having similar experiences as me...they should be sued. I'll never buy another Netgear product. What I'll get Comcast to do is install their own modem since most of what is out there is crap now. Then they can replace their own junk when it goes out. I installed 2 Arris T25's before this and they were both garbage....first one never came up and the second caused constant static on the telephony lines. I give up and I'm not someone who does.
db3058 wrote:Do you work for Netgear?...your responses do not make sense. There are thousands upon thousands of reviews on the net indicating the modem is junk...I'm the fool who had hope. What I'll get Comcast to do is install their own modem since most of what is out there is crap now. Then they can replace their own junk when it goes out. I installed 2 Arris T25's before this and they were both garbage....first one never came up and the second caused constant static on the telephony lines. I give up and I'm not someone who does.
If you are talking to me, no, I do not work for Netgear. I am a retired electrical engineer who worked for 45+ years in the communications business. Mostly machine controls. I came to this community some years ago and asked for help. It was willingly provided and resolved the issue I was working on. I pay the community back when I can.
The sooner you start having Comcast charge your credit card for a gateway lease, the better you will feel.
My CM2050V has been in service since September 2021 and has not missed a beat. The first firmware update was a few weeks ago as Comcast is working on their infrastructure for the mid-split configuration update.
