db3058
Sep 26, 2023Guide
Nighthawk CM2050V Comcast Firmware Killed Speed
I understand Comcast has just updated the firmware in these routers from V2.01.03 to V9.01.01. My download speed went from 934 to 225. Comcast tech came out yesterday and cleared some signal loss b...
- Oct 24, 2023
I contacted a supervisor who actually responded he could see the modem was not properly provisioned, he opened another ticket and one of their best techs came out. I think they fixed it from inside but he was excellent. Problem solved after a month and about 15 tickets opened. Thanks for the encouragement
db3058
Oct 21, 2023Guide
I installed the NEW Netgear CM2050V that arrived yesterday. The bad news is nothing has changed. The speed is still 600 Mbps slower than it was when the original CM2050V was installed in June. So Comcast has done something to kill the speed. Funny thing is I installed it at the pole because my cell will not work in the house (mountains...middle of nowhere) and although the gigabit data light on the modem was blinking I was still getting the exact same speed back of the modem as the one I replaced. So with Comcast saying I'm getting 1500 Mbps to the modem why is the modem only passing 350-360, and down to 212 hard wired LAN when it was 934. They without a doubt changed something that killed the speed in this particular modem. My buddy down the street is using an Arris T25 because he doesn't mind the horrible static on the VOIP and his speed is close to 900. Something in the new software provisioning as of 2 months ago is not compatible with the Netgear CM2050V. It is only 1 of 2 modems on their website that they indicate is compatible with speed 800 and above with telephony. Evidently that's nonsense. I guess they found a way to only allow their proprietary modems to pass high speeds through....at least that's what I'm thinking.
- KitsapOct 21, 2023Master
db3058 wrote:I installed the NEW Netgear CM2050V that arrived yesterday. The bad news is nothing has changed. The speed is still 600 Mbps slower than it was when the original CM2050V was installed in June. So Comcast has done something to kill the speed. Funny thing is I installed it at the pole because my cell will not work in the house (mountains...middle of nowhere) and although the gigabit data light on the modem was blinking I was still getting the exact same speed back of the modem as the one I replaced. So with Comcast saying I'm getting 1500 Mbps to the modem why is the modem only passing 350-360, and down to 212 hard wired LAN when it was 934. They without a doubt changed something that killed the speed in this particular modem. My buddy down the street is using an Arris T25 because he doesn't mind the horrible static on the VOIP and his speed is close to 900. Something in the new software provisioning as of 2 months ago is not compatible with the Netgear CM2050V. It is only 1 of 2 modems on their website that they indicate is compatible with speed 800 and above with telephony. Evidently that's nonsense. I guess they found a way to only allow their proprietary modems to pass high speeds through....at least that's what I'm thinking.
Information to adjust your thinking.
On paper my Comcast plan is 1000/15 Mbps. With the standard 20% over provisioning, it comes out to 1200/18 Mbps. The firmware on my CM2050V was updated last month.
The output from the modem goes through a 6 ft. Cat 6A patch cord to a RJ45/SPF+ adapter to the SPF+ input on my R9000 router.
Appropriate screen snips in attached PDF file. One from the modem user interface, one from the advanced statistics page on the router, and one history page from the Nighthawk mobile application. The mobile application test measures throughput at the input to the router.
Now that you have tried two different modems with the same results, you should consider looking at the other pieces that make up your LAN or your test methodology.
- db3058Oct 21, 2023Guide
I measured the speed back of the modem RJ45 outside on the street at the base of the pole before it goes underground via conduit to my garage. None of my wiring or other equipment was connected. The drop from the pole comes to a pole on my land RG11, 50 ft. Then it runs underground conduit RG11 to my garage and RG6 to the modem. I saw the Comcast tech's test equipment measure 1500 Mbps. at every break point. I eliminated the possibility of it being any of my peripheral equipment or wiring early on and stayed consistent measuring the speed at the base of the pole, back of the modem direct with my laptop. Actually that's the only place I can get a shaky cell signal on my property. I'm only measuring what comes through the CM2050V, 50 ft from their output in the street. It's the same speed I get when moving the modem inside and measuring off the RJ45 on the modem direct from the drop before any of my stuff is a factor. I get 345 Mbps at those points so my router is dropping the speed about 120 Mbps. Just to do so I replaced the cords, Comcast wired splitter, router and switch attached to it early on...I have 2 of everything. So installing a new 3.1 router will have some benefit but still won't get me anywhere near what I'm paying for or what I had 5 weeks ago.
What 3.1 wifi router can anyone recommend? Researching stand alone routers and mesh systems I'm seeing so many complaints on Amazon and Best Buy that I'm hesitant to buy anything. My old Asus router has been so reliable.
