db3058
Sep 26, 2023Guide
Nighthawk CM2050V Comcast Firmware Killed Speed
I understand Comcast has just updated the firmware in these routers from V2.01.03 to V9.01.01. My download speed went from 934 to 225. Comcast tech came out yesterday and cleared some signal loss b...
- Oct 24, 2023
I contacted a supervisor who actually responded he could see the modem was not properly provisioned, he opened another ticket and one of their best techs came out. I think they fixed it from inside but he was excellent. Problem solved after a month and about 15 tickets opened. Thanks for the encouragement
db3058
Oct 21, 2023Guide
I have 6 laptops, older Windows 7 Pro Latitudes and mostly new Windows 10 Latitudes. I know what I'm doing. They all have ethernet ports or I could not measure the speed at the back of the CM2050V and they are all consistent with each other. It's the same laptops I measured 934 Mbps 5 weeks ago. Comcast changed something in the mountains I'm living in far from any city to get the signal up here. If I've proved anything it's not the CM2050V or any of the hardware on my end or the wiring from Comcast to my home. There is nothing left but whatever hardware Comcast is using to push the signal up here being toxic to this modem. It's similar to the repeaters the phone company uses to push dial tone on copper to rural areas. It's not straight copper anymore like the city. It goes through repeaters. And the tech changes. We used slicks back in the day. Now ATT has little powered substations with a different kind of repeater. Data will not pass through the repeaters on the telephony network but you still get dial tone. I'm sure Comcast is similar...I'm 30 miles from the nearest small city. Comcast has small substations along the way to push the signal a long long way. I'm sure if I took this setup to the city it would work fine. They may have hosed the speed with this particular modem but it's still better than the Starlink alternative. Comcast's proprietary modems may work better but I'm not paying them any more money to find out.
Kitsap
Oct 22, 2023Master
db3058 wrote:I have 6 laptops, older Windows 7 Pro Latitudes and mostly new Windows 10 Latitudes. I know what I'm doing. They all have ethernet ports or I could not measure the speed at the back of the CM2050V and they are all consistent with each other. It's the same laptops I measured 934 Mbps 5 weeks ago. Comcast changed something in the mountains I'm living in far from any city to get the signal up here. If I've proved anything it's not the CM2050V or any of the hardware on my end or the wiring from Comcast to my home. There is nothing left but whatever hardware Comcast is using to push the signal up here being toxic to this modem. It's similar to the repeaters the phone company uses to push dial tone on copper to rural areas. It's not straight copper anymore like the city. It goes through repeaters. And the tech changes. We used slicks back in the day. Now ATT has little powered substations with a different kind of repeater. Data will not pass through the repeaters on the telephony network but you still get dial tone. I'm sure Comcast is similar...I'm 30 miles from the nearest small city. Comcast has small substations along the way to push the signal a long long way. I'm sure if I took this setup to the city it would work fine. They may have hosed the speed with this particular modem but it's still better than the Starlink alternative. Comcast's proprietary modems may work better but I'm not paying them any more money to find out.
There were Microsoft updates on Sept 12 and 26. Are you sure none of them had an impact on your Ethernet ports or the drivers? Lately Windows updates have had a nasty habit of changing the network profile from private to public. Possibly in response to the new firmware on your modem. You might go check. How long has it been since you went to Dell and checked for OEM updates to the Bios or Ethernet ports on your laptops? Maybe run the Dell Command Update application to check. Since your Comcast signal is so poor, after updates have you run a system file check (SFC) to see if the updates created any file corruption?
- db3058Oct 22, 2023Guide
The laptops are perfect. If there's any corruption I reimage quickly. Yes Microsoft is adept at stuff being corrupted. I just fixed my neighbors laptop with corrupted wifi firmware.
The biggest tell is the gigabit light on the CM2050V flickering when it is getting gigabit speed. That light flickered for 2 months and I constantly measured the speed at 934 to the laptop on my LAN ethernet so it was getting over 1 Gbps. It has been solid for 5 weeks...that's the first thing I noticed and knew something was wrong. The new one I installed yesterday was trying to process the speed (light was flickering for a time) but could not and settled at solid. That was interesting and I was hopeful for a short time.
I just found out yesterday Comcast is rewiring the entire plant to mount the cable on the new PGE poles all new plant redone a few years ago for fire danger. Most of Comcast and ATT are on the old poles or hanging in space because they did not reach. Maybe that will change something....maybe not. I'm at the end of the line for Comcast...most of the development I live in does not have coax or telephony and they're not getting it. They have Hughes Net, Starlink or just a cell phone.
- KitsapOct 22, 2023Master
The DOCSIS 3.1 specification applies only to modems, not to routers.
Good luck.
- FURRYe38Oct 22, 2023Guru - Experienced User
One last try since we asked about this before, Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
