Jgeorge's avatar
Jgeorge
nighthawk cm2500
Should the cm2500 cable modem have the aggegatre port enabled or disabled in th administration page? I'm using only one ethernet port to my router.
  • FURRYe38's avatar
    Aug 13, 2024
    If you don't have a LAG enabled wifi router connected or are using LAG, then that feature should be disabled.
