Jgeorge
Aug 13, 2024Aspirant
nighthawk cm2500
Should the cm2500 cable modem have the aggegatre port enabled or disabled in th administration page? I'm using only one ethernet port to my router.
- Aug 13, 2024
If you don't have a LAG enabled wifi router connected or are using LAG, then that feature should be disabled.
Aug 14, 2024Guru - Experienced User
what router do you have?
the link aggregation lets you go above the 1 gig limit of the ports.
