Newhomer
Feb 24, 2020Aspirant
Nighthawk model c7100v does not handle gb speeds ?
Was told by Comcast that this router doesn't handle gigabit speeds without a firmware upgrade to docsis 3.1. Anyone know if the latest firmware makes this possible ?
Feb 24, 2020Guru - Experienced User
There's no "upgrade the C7100v firmware" to docsis 3.1.
Docsis 3.1 is a harware change and not a firmware change.
You can buy a device with Docsis 3.1 capabilities like the C7800 that supports gigabit and has integrated router.
- NewhomerFeb 24, 2020AspirantThanks for the info. Thought that might be thr case. Guess a new modem/router is my next step.
- plemansFeb 24, 2020Guru - Experienced User
Newhomer wrote:
Thanks for the info. Thought that might be thr case. Guess a new modem/router is my next step.Just my 2 cents but I prefer to buy the modem and router seperate. That way you control the firmare on the router and can get the latest updates/upgrades. Plus if something goes wrong, its only 1 device that goes bad and you're not out a more expensive combo device.
but some prefer combo devices for the ease and integration
- NewhomerFeb 24, 2020AspirantI'll check Comcast for models of each that are compatible.
- FURRYe38Feb 24, 2020Guru - Experienced User
The CM1100 handles 1Gb services nicely if you wanna go with a modem only unit and then get yourself a external router. Besure if you go this route, ensure that the router you get supports 1Gb services. Some older routers don't. NGs R7800 and foward models do support 1Gb WAN to LAN thruput speeds.
