imylee16
Mar 12, 2020Follower
Nighthawk Modem Router Combo Not Close to 1000mbps
Hi all. I recently purchased a Nighthawk C7800/AC3200 modem router combo to use with Comcast Xfinity wifi. I'm supposed to be getting up to 1000 mbps but after multiple speed tests right next to the ...
Mar 12, 2020Guru - Experienced User
1. How are you testing? wired/wireless? Make sure to test over a wired connection. make sure you're getting full speed wired. So what speed do you get over a wired connection
2. What website are you testing on?
3. What device are you testing with?
4. If you log into the c7800 modem connections page, take a screen snip of your modem connections. Comcast is great at saying a line is fine when its not.
