sail8
Apr 14, 2025Aspirant
Nighthawk Speed - Device or Provider?
Just recently returned my C7000v2 and got a AX6000 (CAX80) and noticed that despite it working overall I was getting relatively low speeds. I pay for 1300mbps through xfinity and have noticed that I...
michaelkenward
Apr 14, 2025Guru - Experienced User
sail8 wrote:
I pay for 1300mbps through xfinity and have noticed that I’m getting only 200-300mbps on average.
Measured how? 300 Mbps is as fast you will get on many wifi devices.
Disclaimer: Just another user with time on their hands.
- plemansApr 14, 2025Guru - Experienced User
wifi speeds drop off quickly with distance and obstructions. 300 Mbps through walls/distance isn't bad.
What speed do you get hardwired?
Thats the key.
