AntContreras
Jan 28, 2020Aspirant
Nighthawk x10 R9000 or XR700 + modem help
Hi all , I had a couple questions regarding routers and modems and best options for gaming and streaming.
I currently have the option of selecting between the NightHawk Pro Gaming XR700 and the Nighthawk X10 R9000. And I am honestly unsure on a modem.
My house is about 1200 sq ft. and our internet service provider is xfinity... I’ll be wired for gaming but WiFi for everything else. We also have 3 nest cameras on the WiFi as well.
So I’m wondering which router would work out best and if you can give me any suggestions on a compatible modem? I’m currently using the one the cable company provides (2 in 1 router modem combo).
Also what would the ideal setup be for either of the routers and modem? I don’t really understand the many different ports but I just know I need a way better setup.
Thanks a bunch in advance
Any chance your ISP officially supports a CM1100 or CM1200 cable modem. If your ISP is cable.
I personally was not impressed with either R9000 or XR700. Both are wireless AD supporting which hasn't seemed to really taken off or seen much support in the client HW side of things. AX seems to be getting more traction and getting more support. I would not recommend spending money on wifi features that don't seem to have a wide support range.
Seen various issues from users with the R9000 and XR700. I would highly recommend reviewing forums for these two router models before you buy. There is a netduma forum as well for the XR700 on there site. They also help support the XR300, 450 and 500 routers. NG forum is also here this site as well.
I have the XR450 and have been enjoying it greatly. :heart:Thought I have it's wifi radios disabled and use Orbi MESH wifi system for my wifi. If you think AX is more in your direction, you might give NG's RAX series of routers a try, or ASUS AX-11000 router a demo. I enjoy mine. :smileywink:
Thanks a bunch in advance- AntContrerasAspirantHi thanks for the reply. I have xfinity from Comcast and after looking it up, it looks like they do support both of those modems you mentioned. Do you recommend them?
As far as the routers I’m not really too sure what the difference is between AD and AX.. I honestly don’t know a thing about internet routers or modems lol :/.... I guess I just figured I’ll look up the best routers for gaming and streaming and the two I questioned about both kept coming up. I just know I really need to upgrade and finally get rid of the modem router I’ve been renting from Comcast for wayyyyy tooo long. If you don’t mind explaining to me the difference between the AD and AX and how they might benefit that’d be awesome. Sorry I’m just really confused lol.- FURRYe38Guru - Experienced User
I have both modems. CM1100 is currently online. I have two routers connected to the CM1100 getting two different IPs from my ISP. Sharing my 1Gb ISP service. I would recommend them.
https://en.wikipedia.org/wiki/IEEE_802.11ad
https://en.wikipedia.org/wiki/IEEE_802.11ax
AX seems to becoming more and more popular and the new wifi standard. It's draft standard is supposed to be finalized this year.
