RegularDude
Dec 13, 2019Aspirant
Nighthawk X4 - WiFi Cable Modem Router - Unable to connect to 5ghz
Up until today, all of my devices have been connected to my 2.4ghz radio - with no issues. Since I recently added a few new devices, I decided to spread them across both my X4's radios. SSD only di...
Dec 14, 2019Guru - Experienced User
If you're using any special characters in your password, remove them. They can occassionlly create issues.
Another thing to try is to disable the password entirely. If it works, it means the wifi is fine, its something to do with the password setup or password itself.
RegularDude
Dec 14, 2019Aspirant
Okay, not sure why I didn't try that before. I turned off the security and it functioned fine. Once I add the WPA2-PSK [AES] security (and the SAME password as was entered for the 2.4ghz radio), I'm unable to authenticate then. I tried the same password (which had no special characters), variants with caps and no caps, even all numbers (since the field can take 8-63 characters or 64 hex digits). Once I create a PW to secure it, I can't authenticate.
- plemansDec 14, 2019Guru - Experienced User
Is it only certain wireless devices? Aka, android, IOS, smart devices?
What all types of devices are affected?
Another thing you can possibly try is setting the 5ghz speed down. Shouldn't impact it but its worth a shot.
- RegularDudeDec 14, 2019Aspirant
Hey, plemans - this is occurring with my Android devices, smart televisions, Roku's, etc. Basically any wireless device that I wish to connect to the X4 on the 5ghz radio. By default, the speed is set to 'Up to 2165 Mbps'. Last night, I dropped it down to 'Up to 1000 Mbps', to match the speed setting of my 2.4ghz radio. It didn't work when I tried it. So I'm unsure where to go with this next. The 5ghz works, but once I add a form of security to it, none of the devices are able to connect to it. Those same security policies function perfectly on the 2.4ghz radio. My devices are compatible with both bands - and it hasn't been an issue with my previous routers.
Have you tried a factory reset and reinstall?
