JasonProcell's avatar
Jan 09, 2019
Nighthawk x4 c7500
I’ve had this nighthawk x4 c7500 for almost a week and it started with the 5GHz antenna dropping and now both wireless radios stop working. I can pull power to reboot and can connect for about 5 minutes before it stops working again!
  • I've had consistent internet disconnects from my C7000 router on Comcast and I've played factory resets on it 2 days straight without finding a solution to the wireless & wired problems. The truth I've come to realize late is that this hardware is best to return and get a refund if possible and remember there are far more reliable options available elsewhere. I'm done with this brand. Never again.
    • JasonProcell's avatar
      JasonProcell
      Tutor
      I still like the user interface better than the arris, so I bought the DOCSIS 3.1 which was $400 and I’m hoping it works better than this one! If not, I’m done too!!
      • NeverNetg3ar's avatar
        NeverNetg3ar
        Tutor
        Quick question - I'm curious if you recently connected any Nest devices, specifically Nest Connect, and then began experiencing internet connection issues. It belatedly occurred to me that I may have had an operational WiFi until I added Nest Protect, Connect and Yale lock.
