bradsod189
May 16, 2019Follower
Nighthawk X4S - stopped broadcasting wifi?
I've had our X4S for about 8-9 months, and it's successfully broadcast both a 2.4 and 5gHz signal through our house. However, a few days back, both signals simply disappeared. Nothing changed in our ...
May 17, 2019Guru - Experienced User
Has a factory reset been performed on the modem and setup from scratch? After doing the reset, check with a wifi device to see if you can see the factory default wifi SSID being broadcast. If you don't, the wifi on the modem maybe bad...
