Sevvy
Apr 24, 2017Aspirant
Nighthawk X4S AC2600 (D7800) slow wireless speeds
Hi all - My two year old TalkTalk "Super Router" was giving me a bit of trouble , so i invested over £200 in a Netgear Nighthawk X4S -AC2600 modem router after reading excellent reviews of it in se...
Sevvy
May 03, 2017Aspirant
Unfortunately I don't have anything I can plug into it using Ethernet as my new Lenovo laptop is wireless only -
I also have an iPhone,iPod and Samsung tablet - all wireless -
if I log into the router 192.168.1.1 homepage it shows my incoming broadband speed as 28.8 Mbps , and yet I can only get 15.8 max when using wireless , even right next to the router
DarrenM
May 03, 2017Sr. NETGEAR Moderator
Hello Sevvy
Sometimes a signal device connected to the network could be slowing down the whole wireless network you could test this by removing all devices and adding them 1 by 1 and testing the speed. You will know pretty quick if you start with your laptop only and the speeds are still slow if there is a issue with the wireless on the unit.
DarrenM
