brod625
Mar 20, 2019Initiate
Nighthawk x4s Ac3200 C7800 2.4ghz band issue
Hi all,
I'm sure this has been addressed many times on other models, but this one I haven't seen specifically with this model (AC3200 X4S)
For the last few weeks, I've been having trouble with my 2.4 ghz band connecting to things on my Nighthawk X4s Cable Modem Router Ac3200 C7800. It either doesn't allow any connections, anything that connects to it says "connecting" and fails after a period of time, or barely gives any data.
I've tried rebooting, changing multiple settings like 20/40 mhz coexistence, changing ports, changing the DNS servers, what say you.
An example I can give as to how it doesn't work is my Samsung NU7200 TV. It can only connect to the 2.4 GHz band. It will say that it is connected, go through the tests fine. But, once I go onto an app in the TV, such as YouTube, it will say that YouTube is unavailable, or it will continue to buffer.
I'm kinda at my wits end. I'm with a local cable company for my internet, with the firmware V3.01.36. I'd like to know (especially with a Netgear Moderator) if there's a fix in the works or an actual fix.
Thank you!
Thank you!
- microchip8Master
have you done a factory reset?
- brod625InitiateYes, I have rebooted it and a factory reset to no avail.
- YitsyAspirant
Bumping this topic. Once 5GHz has been activated 2.4GHz is not available and has 0 internet connectivity, I have devices in my house that do not support 5GHz.
Things I've tried
- Factory Reset
- Different placement in the house
- Turning on/off 20/40 MHz Coexistence
- Tried multiple channels with a preference to 1/7/11
Some support on this would be fabulous and hopefully, Netgear can get their stuff straight. I've been hopping between forums and this has been a common issue. I am feeling disappointed investing in this piece of hardware. :smileyindifferent:
