aanders50
Jan 22, 2024Guide
Nighthawk X4S AC3200 (C7800) configure upload speed?
Hello, I am trying to see if there is a way for a regular person like myself to "configure" the upload speed of my C7800. Recently, Xfinity changed our areas upload caps from 40mbps to 200mbps. I ...
aanders50
Jan 22, 2024Guide
Okay! Yea that was part of my initial question to Xfinity as well. Do we know if that list is concrete? I was under the impression that Xfinity was still adding more models (or at least it seemed like it was being populated over time).
I originally had asked the Xfinity person if they knew of a timeline and they simply said yes / that they would try to provision it.
Thanks!
Jan 22, 2024Guru - Experienced User
that list is getting devices slowly added. I don't forsee the C7800 being added because its built in modem is basically the CM1000. And I don't expect that to get added to xfinity's list. The C7800 and CM1000 are first generation docsis 3.1 devices. Xfinity won't even release if they're working on the CM2000 which is multigig and has the capability
