gpogliano
Nov 12, 2021Aspirant
Nighthawk X4S C7800 Drops Connection to Online Matches XBOX ONE X
Hello, I have been having an issue for a few months now with my C7800 and Xbox One X. The connection is hardwired in, and internet speeds are great but I will frequently lose connection to online...
gpogliano
Thanks for the quick reply! I just tried this and hopped in a couple games. Small sample size so far, but it seems to be working! I'll try to remember to update after a few more games to see if it held. Last question, how worried should I be about security with this setup?
Nov 12, 2021Guru - Experienced User
I personally would not recommend using DMZ for any game console. Could lead to nefarious attackers trying to gain access or do nefarious things while you game online.
What Cat version is the lan cable between the modem and game console? CAT6 is recommended.
If you set up port fowarding, then uPnP should be disabled. If your the only one gaming online with xbox, then PF is not needed and uPnP should work for gaming online.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
- gpoglianoNov 12, 2021Aspirant
Thanks for the response!
Current firmware is V3.01.40, which matches the current firmware for "Other ISP" from Netgear's website.
Lan cable is CAT 5e, so I could look at upgrading that.
There is only one Xbox on the network, and uPnP is on when I started experiencing the issue. When I tried to set up port dorwarding, I did not turn uPnP off, which may have been the reason it didn't work?
There are no coax cable splitters that I am aware of, I don't know a lot about coax cable but mine says it is PPC Perfect Flex 6 series and seems sturdy, and I have tried multiple full restarts (turn off, remove power, wait 1 minute, plug in and turn on).
- FURRYe38Nov 12, 2021Guru - Experienced User
Lan cable is CAT 5e, so I could look at upgrading that. Try CAT6.
There is only one Xbox on the network, and uPnP is on when I started experiencing the issue. When I tried to set up port dorwarding, I did not turn uPnP off, which may have been the reason it didn't work? Correct. If you have 1 game console only, then you only need uPnP.
Has a factory reset and setup from scratch ever been performed?
