TheDax255
Oct 03, 2020Tutor
Nighthawk X4S C7800 not supported by Spectrum?
So, i just moved and had to change services from WOW to Spectrum. I was using the C7800 on wow just fine, and on the box it SAYS Spectrum on it... but when i go to set it up, they say it's not suppor...
Oct 04, 2020Guru - Experienced User
It used to be supported. And I know it does work as my in-law is using a C7800 on spectrum currently.
Not sure why its not on their list anymore for the 1gig link. Its currently on the "minimally supported" list.
https://www.spectrum.net/support/internet/compliant-modems-spectrum-network/
Any ideas vkdelta ?
