dnewell215
Apr 26, 2020Aspirant
Nighthawk x4s C7800 w slow speeds from Xfinity Gigabit
Hello! I've had my C7800 for a little over a year with Xfinity Gigabit as my ISP. When I first got it, I was getting wired connections around 800+ Mbps, 5Ghz WiFi at 400+ Mbps, and 2.4 Ghz Wifi ...
Apr 27, 2020Guru - Experienced User
1. log into the modem and get a screen snip of the cable connections page. it shows the connection back to the isp.
2. you're using the speedtest app? If so, try testing with speedtest.xfinity.com or dslreports.com the speedtest site can pick bad servers sometimes and give inconsistent results.
3. Have you tried checking the cable on the hardwired device?
- dnewell215Apr 28, 2020Aspirant
Screenshots of the Connections page attached.
I re-tested using the Xfinity speedtest. Results were similar: Enthernet at 94Mbps, 5Ghz at 325Mbps, 2.4Ghz at 39Mbps.
The hardwired device is connected with a 6ft cable that is in perfect condition, so the physical cable does not appear to be the problem.
plemans Thank you very much for your response and help!
- plemansApr 28, 2020Guru - Experienced User
the 94mbps ethernet seems like its only negotiating a 10/100mbps connection and not gigabit.
What device are you testing hardwired with? I've ran into issues with ethernet adapters not negotiating the right connection speed, drivers being out dated, cable being bad, or even just not a gigabit adapter.
any other hardwired devices you could test with?
And check/swap the cables.
- dnewell215Apr 28, 2020AspirantAll tests were done using a MacBook Pro. I used a brand new Apple Ethernet-USB adapter to connect (bought it just to do this test).
I’d have to swap a cable out later when I have access to one, but the one that’s here worked fine for a long time, and then all of a sudden it didn’t.
page 2 of the connections page
