dnewell215
Apr 26, 2020Aspirant
Nighthawk x4s C7800 w slow speeds from Xfinity Gigabit
Hello! I've had my C7800 for a little over a year with Xfinity Gigabit as my ISP. When I first got it, I was getting wired connections around 800+ Mbps, 5Ghz WiFi at 400+ Mbps, and 2.4 Ghz Wifi ...
dnewell215
Apr 28, 2020Aspirant
Also, if the C7800 is the supplying both the hardwired and WiFi connections, how would the 5Ghz be performing at 325Mbps, while the hardwired is performing at 94Mbps?
Sorry if this is not the best question... I know just enough time be dangerous about IT, but it’s not my area of expertise by any means.
Apr 28, 2020Guru - Experienced User
the c7800 is a cable modem/router combo device. If the c7800 is getting full speed, the wireless will work fine. But if the cable connecting it to the pc isn't rated gig, is bad, or even the device isn't linking at gigabit, it'll only pull the 94mbps because of overhead.
that's why I'd check
1. the cable
2. the device
