RhayK
Nov 19, 2016Aspirant
Nighthawk X4S D7800 - Port Forwarding problem
Nighthawk X4S D7800 Router Firmware Version V1.0.1.16 I setup port forwarding as per the manual but I am not successfully connecting to my internal IP address. Please help. Port Forwarding ...
TheEther
Nov 19, 2016Guru
Something has to be listening on the opened port at 192.168.1.200 in order to respond to a port checking service.
If you don't have something running then Connection refused is actually a good sign because it signifies that 192.168.1.200 responded that nothing is listening on that port, which proves that the router forwarded the port.
- RhayKNov 19, 2016Aspirant
NIghthawk X4S D7800 - port forwarding connection refused
I am able to access 192.168.1.200 (device) within my home network.
I tried to setup port forwarding on my D7800 router but Open Check Tool returned thi message "Problem! I could not see your service on 137.147.139.17 on port (2020).
Reason: Connection refused. "I tried to check the port used for Remote Management, Open Check Tool "Your ISP/Router/Firewall is not blocking port 4444"
Is this something to do with the firewall?
My PC setup:
OS Windows 8.1
Kaspersky Internet Securities 2016
Malwarebytes Anti-malware Home
Currently my ISP using Dynamic IP
Please help .
