Gaz77a
Dec 30, 2016Aspirant
Nighthawk X4S D7800 Address Reservation not working
I have recently bought the X4S and can't get the address reservation to work. I have read that NETGEAR have issues in the past for other models. Is there a solution for the X4S? Details F...
Orange-Phantom
Feb 08, 2017Aspirant
I've got exactly the same issue!
I'm still waiting for a fix as several of my devices require a specific IP and fixing it within the router is the best option, except the latest Firmware has broken it!
I've tried everything to fix it, but am now aware it's the firmware that's at fault!
Also the 5Ghz band keeps losing data transfer on several of my devices then magically gets it back again
Please Netgear release a new firmware that fixes these issues, I paid enough for this router, I expect alot better from you.
Cesare_
Mar 22, 2017Aspirant
I, I would like to buy the D7800 but I have 3 issues:
1) Does the IP address reservation work? On the D7000 the bug has been fixed;
2) few users reported loss of communication with NAS permanently connected hard wired to the D7800. Do you have experienced any problem?
3) I need port forwarding. Does it work?
Anything bad still to note?
Thank you
Cesare
