Gaz77a
Dec 30, 2016Aspirant
Nighthawk X4S D7800 Address Reservation not working
I have recently bought the X4S and can't get the address reservation to work. I have read that NETGEAR have issues in the past for other models. Is there a solution for the X4S? Details F...
Gaz77a
Mar 22, 2017Aspirant
1) Yes it does. You just have to ensure your reservation ips are in the dhcp range.
This is different to other routers that must have the ranges not overlapping.
2) I have had some issues with AirPlay devices attached. I haven't confirmed if it is an issue with the router.
3) port forwarding appears to work.
4) The wifi performance and range is excellent
- Cesare_Mar 24, 2017Aspirant
Thank you. Much appreciated.
What firmware revision are you using?
Are you having any benefit from the MU-MIMO?
Have you tryied the Opme VPN?
As I need to buy a new router now, would you go for it or is there any drawback? My only alternative would be the D7000 as I have seen that with a specific firmware revision the 3 items of my revious post are working fine.
Bye
Cesare
