bilbowebuser's avatar
Feb 20, 2017
Nighthawk X4S D7800 firmware issues
I have just received a replacement router (D7800) because my previous one started having problems with the internet connection: the internet connection would appear to stop working, yet the modem was...
  • JCHH's avatar
    JCHH
    Apr 06, 2017
    I nopticed that DST was not set under "schedule".  I checked it and, voila, the time was set correctly and the QoS performance database has just updated.
    try it!
