bilbowebuser
Feb 20, 2017Tutor
Nighthawk X4S D7800 firmware issues
I have just received a replacement router (D7800) because my previous one started having problems with the internet connection: the internet connection would appear to stop working, yet the modem was...
- Apr 06, 2017
I nopticed that DST was not set under "schedule". I checked it and, voila, the time was set correctly and the QoS performance database has just updated.
try it!
JCHH
Apr 06, 2017Aspirant
I have exactly the same issue, but my details are:
firmware: 1.0.1.16
d/base v 3.0607 (June 07 2016)
Did you get through to Netgear on this?
Thanks,
James.
JCHH
try it!
