l3ully
Sep 23, 2016Tutor
Nighthawk X4S D7800
I have an issue with static ip address' on the lan side of router. I have setup address reservations but when I turn on these devices mainly Xbox ones it never gets the IP address set? I have tried...
- Sep 24, 2016
Ok I have found the issue, it is the latest firmware V1.0.1.10 that is the problem, rolled back to V1.0.0.48 and is working fine now.
l3ully
Sep 24, 2016Tutor
l3ully
Oct 02, 2016Tutor
I seem to have another issue, occasionally the fibre connection disconnects and does not automatically reconnect, the only way I can get connection back is to reboot router.
