DaveMoreland
Aug 15, 2022Aspirant
Nighthawk X4S Slow Download Speeds
My X4S AC3200 cable modem occasionally will have the download speeds slow to 1 mbps or less while the uploads remain normal at 35-40 mbps. I am paying for 400 mbps download speeds. You can restore ...
- Aug 16, 2022
Ok hoping you or ISP and get it working better...
Aug 15, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and PC. CAT6 is recommended.
What is the connection rate seen on the PCs ethernet adapter. Should see 1000Mpbs
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=2431
DaveMoreland
Aug 16, 2022Aspirant
1. Yes, we are using CAT6.
2. Connection rate is 1000 Mbps
3.
| Frequency start Value | |
| This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |
<tabindex=-1>Startup Procedure</tabindex=-1>
| Procedure | Status | Comment |
| Acquire Downstream Channel | 561000000 Hz | Locked |
| Connectivity State | OK | Operational |
| Boot State | OK | Operational |
| Security | ENABLED | BPI+ |
| IP Provisioning Mode | Honor MDD | APM |
<tabindex=-1>Downstream Bonded Channels</tabindex=-1>
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | Uncorrectabables |
| 1 | Locked | QAM256 | 1 | 561000000 Hz | -9.3 dBmV | 35.9 dB | 1 | 0 |
| 2 | Locked | QAM256 | 2 | 567000000 Hz | -9.8 dBmV | 35.7 dB | 2 | 0 |
| 3 | Locked | QAM256 | 3 | 573000000 Hz | -9.4 dBmV | 36.0 dB | 6 | 0 |
| 4 | Locked | QAM256 | 4 | 579000000 Hz | -10.3 dBmV | 35.5 dB | 10 | 0 |
| 5 | Locked | QAM256 | 5 | 585000000 Hz | -10.1 dBmV | 35.6 dB | 5 | 0 |
| 6 | Locked | QAM256 | 6 | 591000000 Hz | -10.4 dBmV | 35.7 dB | 5 | 0 |
| 7 | Locked | QAM256 | 7 | 597000000 Hz | -10.6 dBmV | 35.5 dB | 7 | 0 |
| 8 | Locked | QAM256 | 8 | 603000000 Hz | -10.8 dBmV | 35.2 dB | 18 | 0 |
| 9 | Locked | QAM256 | 9 | 609000000 Hz | -10.9 dBmV | 35.3 dB | 5 | 0 |
| 10 | Locked | QAM256 | 10 | 615000000 Hz | -11.3 dBmV | 35.0 dB | 4 | 0 |
| 11 | Locked | QAM256 | 11 | 621000000 Hz | -12.1 dBmV | 34.7 dB | 13 | 0 |
| 12 | Locked | QAM256 | 12 | 627000000 Hz | -12.8 dBmV | 34.5 dB | 16 | 0 |
| 13 | Locked | QAM256 | 13 | 633000000 Hz | -12.4 dBmV | 34.7 dB | 16 | 0 |
| 14 | Locked | QAM256 | 14 | 639000000 Hz | -11.9 dBmV | 34.8 dB | 20 | 0 |
| 15 | Locked | QAM256 | 15 | 645000000 Hz | -11.0 dBmV | 35.1 dB | 5 | 0 |
| 16 | Locked | QAM256 | 16 | 651000000 Hz | -11.0 dBmV | 35.0 dB | 7 | 0 |
| 17 | Locked | QAM256 | 17 | 657000000 Hz | -10.7 dBmV | 35.1 dB | 5 | 0 |
| 18 | Locked | QAM256 | 18 | 663000000 Hz | -10.6 dBmV | 35.2 dB | 5 | 0 |
| 19 | Locked | QAM256 | 19 | 669000000 Hz | -10.2 dBmV | 35.2 dB | 7 | 0 |
| 20 | Locked | QAM256 | 20 | 675000000 Hz | -10.9 dBmV | 35.0 dB | 3 | 0 |
| 21 | Locked | QAM256 | 21 | 681000000 Hz | -10.0 dBmV | 35.3 dB | 3 | 0 |
| 22 | Locked | QAM256 | 22 | 687000000 Hz | -10.7 dBmV | 35.2 dB | 6 | 0 |
| 23 | Locked | QAM256 | 23 | 693000000 Hz | -10.1 dBmV | 35.3 dB | 4 | 0 |
| 24 | Locked | QAM256 | 24 | 699000000 Hz | -10.5 dBmV | 35.3 dB | 2 | 0 |
| 25 | Locked | QAM256 | 25 | 705000000 Hz | -9.7 dBmV | 35.3 dB | 21697 | 62905 |
| 26 | Locked | QAM256 | 26 | 711000000 Hz | -10.2 dBmV | 35.2 dB | 26128 | 67909 |
| 27 | Locked | QAM256 | 27 | 717000000 Hz | -9.4 dBmV | 35.4 dB | 1 | 0 |
| 28 | Locked | QAM256 | 28 | 723000000 Hz | -10.2 dBmV | 35.1 dB | 3 | 0 |
| 29 | Locked | QAM256 | 29 | 729000000 Hz | -9.7 dBmV | 35.2 dB | 2 | 0 |
| 30 | Locked | QAM256 | 30 | 735000000 Hz | -10.1 dBmV | 35.2 dB | 1 | 0 |
| 31 | Locked | QAM256 | 31 | 741000000 Hz | -9.5 dBmV | 35.2 dB | 0 | 0 |
| 32 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
<tabindex=-1>Upstream Bonded Channels</tabindex=-1>
| Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power |
| 1 | Locked | ATDMA | 19 | 2560 Ksym/sec | 25000000 Hz | 50.5 dBmV |
| 2 | Locked | ATDMA | 17 | 5120 Ksym/sec | 37500000 Hz | 50.8 dBmV |
| 3 | Locked | ATDMA | 18 | 5120 Ksym/sec | 30700000 Hz | 50.8 dBmV |
| 4 | Locked | ATDMA | 20 | 2560 Ksym/sec | 21400000 Hz | 50.0 dBmV |
| 5 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0 dBmV |
| 6 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0 dBmV |
| 7 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0 dBmV |
| 8 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0 dBmV |
<tabindex=-1>Downstream OFDM Channels</tabindex=-1>
| Channel | Channel ID | Indicator | Subcarrier Zero Frequency | Active Subcarrier Number Range | Total Codewords | Uncorrectable Codewords |
| 1 | 33 | Primary | 677600000 Hz | 1588 ~ 2507 | 249864617 | 0 |
| 2 | 0 | Other | 0 Hz | 0 ~ 0 | 0 | 0 |
<tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
| Channel | UpstreamIsMuted | Ranging Status | Subcarrier Zero Frequency | Active Subcarrier Number Range | Symbols Per Frame | Tx Power |
| 1 | Other | 0 Hz | 0 ~ 0 | 0 | 0 dBmV | |
| 2 | Other | 0 Hz | 0 ~ 0 | 0 | 0 dBmV |
Current System Time: Tue, Aug 16, 2022 12:14:20
4.ISP has been out and has replaced coax beginning at the pole outside all the way into the house. (We had the inside coax replaced)
5. Signal quality has been checked and ISP provisioned modem correctly.
6. No splitters between modem and ISP service box.
7. All interior coax was replaced and new coax professionally installed.
8. Power off procedure has been followed.
- FURRYe38Aug 16, 2022Guru - Experienced User
You power levels are too LOW:
Also you have correct and un-correctables that should be zeros.
Check your coax fittings and ensure they are snug.
Have the ISP check for this and the power levels. The ISP will need to work with you on this.
Be sure to use Ooklas installable speed test app to test speeds with a wired PC. Ensure other devices are disconnected or not using bandwidth before testing.
- DaveMorelandAug 16, 2022Aspirant
Thank you for this info! We have Suddenlink so good luck with their customer service.
I'll do some troubleshooting...does low power level generally indicate signal loss at a splitter or cable connection?
I'll check and make sure there's not a splitter somewhere in the attic that I'm missing.
Excuse my ignorance but what would cause the "correct and un-correctables" issues and what should I be looking for to correct that.
And another stupid question. Does a signal amplifier that would be used on a tv antenna signal help boost a cable internet signal and would there be any advantage to installing an amplifier in this case? Or would that even be possible?🤔
I do use Ookla Speedtest on a wired PC. When it has an issue the download speeds are 1mbps or less and the uploads are in the 40 mbps range. When things are working I generally get anywhere between 90 and 250 mbps downloads with the uploads staying about the same. This speed is restored when we restore the factory settings on the router.
Thanks again for all your help!
Dave
Yes can be due to a splitter or cable connection.
Loose cable jacks or not screwed in all the way, kinked cabling or bad cabling or splitters can cause correct and un-correctables. The modems is trying to correct data flow where i can and can not. This is where this gets reported.
I would ask the ISP first if a amp maybe needed or should be used. Not sure what kind of amp that could be used if one is needed.
