CraigSK
Oct 07, 2020Aspirant
Nighthawk X6S AC3600 Router R7960P wired speed issue
I have a Nighthawk R7960, CM1100 modem, and gigabit internet with Xfinity. We have a computer using an Ethernet connection to the router. When we first got the gigabit internet service, we were onl...
Oct 07, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
What FW version is loaded on the R7960P? Mines on v62
Mines been online since 9/27:
However mines connected to a CAX80 in modem only mode.
QoS not enabled on R7960P
I would try different wired PCs to compare.
Be sure your using good quality LAN cables. CAT6 for all wired connections, including between the modem and router.
CraigSK
Comcast checked the signal and line quality.
R7960P firmware - v1.4.1.50_1.3.10
QoS off
Using modem and router since December 2019.
- FURRYe38Oct 08, 2020Guru - Experienced User
I would update the routers FW, there is more resent version available. Load fw, factory reset and setup from scratch. Power OFF the modem for 30 seconds then back ON when you reset the router.
