JackTheLad
Aug 07, 2019Follower
NightHawk
OK, I'm a bit of a novice here. Just purchaesd the Nighthawk AC3200 to replace my BT Smart Hub 6 which is poor to say the least. I find out now that my phone line will not plug in and I need a seperate modem. What do you recomend?
Please review the CM1150v which support phone line connections:
> [...] replace my BT Smart Hub 6 which is poor to say the least. [...]
"poor" in what sense? Why replace it? If it can be configured in a
modem-only mode, then you ought to be able to use the R8000 as your
router with it.> [...] I need a seperate modem. [...]
If you insist on buying a modem, then Netgear DSL modems have "DM"
model numbers, "DM200", for example. Non-Netgear DSL modems may also
exist.
> [...] BT Smart Hub 6 [...] my phone line [...]> Please review the CM1150v which support phone line connections: [...]
Not a very useful suggestion for a user with DSL service. (Perhaps
even more useless than your usual "My Setup" noise.)
