Alex58
Aug 28, 2020Tutor
Nighthawk(R) X4S R7800 file srver
Hi Guys, Is there a way to assign access to file server with other password than admin? If I want to share a file with someone, I have to open unprotected access until that person downloads the f...
Aug 29, 2020Guru - Experienced User
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
You might try Voxels 3rd party FW as well.
Good Luck.
Alex58
Aug 29, 2020Tutor
Thank you, I will. and also will look at the FW you suggested
2All: please ignore this topic here
