nealp1910
Dec 07, 2021Follower
Nighthawks AC1900 C7000v2 keeps disconnecting
I have a Netgear Nighthawks AC1900 C7000v2 which keeps disconnecting everyday for couple of minutes. This has been happening for couple of months now. The firmware version is V1.03.03. Called my ISP ...
Dec 07, 2021Guru - Experienced User
Lot of criticals that the ISP should look into...
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
