Munski
May 18, 2016Aspirant
No available Firmware for Netgear C3000
I'm having issues with poor connectivity with this combo wifi router. My currect firmware version is V1.01.11, but I've read theres an update available V2.02.08 and nobody seems to have it. My ISP(T...
DarrenM
May 18, 2016Sr. NETGEAR Moderator
Hello Munski
The Firmware for cable modems is pushed out by the ISP so right now there is a newer firmware on some ISP this is because TWC has not pushed the firmware out yet they are still verifying the firmware so I have no ETA on when they would release that firmware. But the problem you are having have you tried to change the wireless channel in the wireless settings?
DarrenM
- MunskiMay 21, 2016Aspirant
I have not tried changing channels. I consider my self computer illiterate and i've read somewhere that it was an option, but i needed to Download a certain progam to find a non occupied channel, alllll this is after i figure out how to even operate the program. It looks complicating.
As far as the firmware, You'e basically saying what I originally posted. Nor you or my ISP currently have the updated firmware. TWC told me to wait on NETGEAR for the update, but now you're saying I need to wait on TWC to push out the update correct? I apologize if i sound frustrated.. Dont get me wrong i appreciate your reply. I just wish i didnt have this problem. Should i contact TWC and ask them to change the channel for me?
- DarrenMMay 24, 2016Sr. NETGEAR Moderator
Munski
That is correct when we make the firmware we then send it out to the ISP then they certify the firmware and make the changes they need to the firmware. After that the ISP will push out the firmware when they are ready to Netgear does not have control of when they want to release the firmware. But I do know that they should be releasing the latest firmware for your device as I heard they are pushing it out over the next couple weeks. As for changing channels I have linked a article with steps on how to do this.
http://kb.netgear.com/app/answers/detail/a_id/23783
DarrenM
- tgurr9094Jun 14, 2016Aspirant
Was the C3000 firmware upgraded lately? I didn't personally upgrade it, but the connected devices page looks different so it may have upgraded itself.
If it was upgraded, were the mail server options upgraded to be able to change the port number?
Thank you!
