rosiejess13
Nov 05, 2018Follower
No GHZ channels or WiFi C6300
I have recently purchased a router/modem C6300. I just moved into apt and hooked it up, it worked fine for about an hour and now Neither 2ghz or the 5ghz channels are lit up. The network will not com...
Nodism1125
Nov 06, 2018NETGEAR Expert
hi rosiejess13,
In the physical unit, check the Wireless On/OFF button. Please check the user manual on page 7-8. http://www.downloads.netgear.com/files/GDC/C6300/C6300_UM_17Nov2015.pdf
Pressing this button for two seconds turns the WiFi radios in the modem router on and off. If this LED is lit, the WiFi radios are on. If this LED is off, the WiFi radios are turned off and you cannot use WiFi to connect to the modem router.
