Jose449
Aug 21, 2022Tutor
No internet access modem
My modem has all lights blinking orange except for 1 is just orange other is blinking green. What does that mean? I have no access to internet either. (It's a CM1000 Cable Modem)
Aug 22, 2022Guru - Experienced User
Are you able to log into the modem?
try starting off with disconnecting the coax cable from the modem and then factory resetting it. Push and hold reset for up to 30 seconds while its powered on. Then let it reboot.
After it reboots. power it back off, reconnect the coax to it. and then power it back on.
Give it a could minutes to fully boot.
then see if you can log into it.
Jose449
Aug 22, 2022Tutor
Tried all steps hard reset for 1min+ (doesn't allow me for some reason) and tried logging in but can't login at all.
- plemansAug 23, 2022Guru - Experienced User
When you have the coax cable disconnect and are pushing/holding reset while powered on, do the lights change at all? Or just stay blinking?
- Jose449Aug 24, 2022TutorThey just stay blinking just power is green the rest are blinking orange even when reset is done nothing occurs (almost like the entire modem is frozen in that error) and can't access the modem either so don't know what else to do
- plemansAug 25, 2022Guru - Experienced User
Sounds like a hardware failure.
Is it still in warranty?
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
