cannondale73's avatar
cannondale73
Follower
Nov 21, 2017
No internet, blinking LED internet light red.
3 days ago, i just randomly lost internet. called my cable provider they said it was fine, modem was working. Net gear router is not allowing me to connect via wireless nor LAN therefor i can not access my genie to see if i need an update, etc. Im not a savy computer person, but was hoping to have suggestions. thanks
jeanine
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    You may want to factory reset the unit by holding the reset button for 10 + seconds and then see if you can access the modem again.
    DarrenM
