daely178
Feb 21, 2023Aspirant
No internet connection with CAX30 from 2/21/23
I see SSID but the Internet connection has been lost since 1:40 AM PST. I tried many power resets, factory resets, and disabling the traffic meter but nothing worked. I talked to someone this morni...
Feb 22, 2023Guru - Experienced User
- daely178Feb 22, 2023Aspirantsuddenly it started working after factory reset again early this morning.
I had traffic meter disabled before issue happened.- FURRYe38Feb 22, 2023Guru - Experienced User
Ok good to know.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
