wdanker
Dec 26, 2016Initiate
No Internet connectivity
I am on Verizon FIOS, the coaxial goes in to their wireless router, which then hardwires into the FS116 switcher. When I connect my comptur directly to the the ethernet cable coming from their wi...
Trikein
Dec 26, 2016Luminary
When you connect direct into the FIOS gateway, what IP address do you get? Don't need to know the exact IP, just wether it is a public (68.1.2.3) or private (192.x.x.x, 10.x.x.x, etc). My guess is the gateway is in bridge mode, so it will only give out 1 public IP, while the switch has 16 ports.
PS. The switch also is only rated for 10/100Mbps. If you pay FIOS for a package above 100Mbps, I would suggest upgrading the switch.
- wdankerDec 26, 2016Initiate
Thanks for the reply. I get a 192.x.x.x address. I also plugged my comptuer directly into the switch to take all the other cable out of play and I cannot see the internet. At this point, I am pretty sure my switcher is fried. Thanks for the reminder on speed. I am getting ready to buy a replacement, leaning to the FS over the GS, I'm on their 50 plan and seem to be able to stream anything I need at this point.
