HermioneDanger
Apr 19, 2017Aspirant
No internet Ethernet light is amber
Hi, just moved and got everything set up fine, but I'm getting an intermittent problem. My internet connection will sporadically go out and my Ethernet light on the modem will turn Amber and occasiona...
HermioneDanger
Apr 20, 2017Aspirant
Further info, the problem is typically fixed by bypassing the router and then getting the internet to come back on then going through the router again. It only last about six hours or so though before going out again.
DarrenM
Apr 21, 2017Sr. NETGEAR Moderator
Hello HermioneDanger
Have you replaced that cable?
DarrenM
