HermioneDanger
Apr 19, 2017Aspirant
No internet Ethernet light is amber
Hi, just moved and got everything set up fine, but I'm getting an intermittent problem. My internet connection will sporadically go out and my Ethernet light on the modem will turn Amber and occasiona...
HermioneDanger
May 05, 2017Aspirant
Not sure which cable you're talking about, but both Ethernet cables are new. I can fix it every time by going into command prompt and using the command
Netsh int ip reset reset.log
And then resetting my modem, my computer, then hooking everything through the router again.
