tatharoy's avatar
tatharoy
Follower
Apr 26, 2020
No Internet via ethernet cable connected to CM500
Hi,   I have a Cable modem cm500 and a wifi router R6080 which i working fine for the past one year. I haven't connected the ethernet cable directly to the modem after the initial setup. But recent...
  • plemans's avatar
    Apr 27, 2020
    Anytime you change whats connected to the modem, it needs to be rebooted.
    Did you do that when you changed devices?
