justme0101
Feb 27, 2017Aspirant
no longer support 802.11 ac
when I first got the router it had phenomenal speed supporting 802.11 ac. now that the new firmware v2.02.08 has installed the router no longer sports 802.11 ac and the gui has changed taking away so...
William10a
Feb 28, 2017Master
The c3700 modem was always working as n netgear router it has 1 gb ports here is a link to the data sheet for it http://www.downloads.netgear.com/files/GDC/datasheet/en/C3700.pdf.
You may need to do a reset on the modem get back to your 106 mb's.
Are your speeds that you are posting wired or wifi?
justme0101
Feb 28, 2017Aspirant
the speeds are wifi not wired
