justme0101
Feb 27, 2017Aspirant
no longer support 802.11 ac
when I first got the router it had phenomenal speed supporting 802.11 ac. now that the new firmware v2.02.08 has installed the router no longer sports 802.11 ac and the gui has changed taking away so...
justme0101
Feb 28, 2017Aspirant
http://www.netgear.com/home/products/networking/cable-modems-routers/C3700.aspx#tab-techspecs so this is a lie just to sell the router and this is from the netgear site. So Netgear lied about the specs online to sell a low end router. i guess i will not buy netgear again
William10a
Feb 28, 2017Master
justme0101 wrote:http://www.netgear.com/home/products/networking/cable-modems-routers/C3700.aspx#tab-techspecs so this is a lie just to sell the router and this is from the netgear site. So Netgear lied about the specs online to sell a low end router. i guess i will not buy netgear again
Sorry that you feel you were misleaded somehow but specs never said it was ac router if just firmware would turn a n router into ac router everyone would do it to their's it is not possible the hardware needed is not there.
As to the speed problem has your isp reset the modem on their end.
- StephenBMar 01, 2017Guru - Experienced User
I see where you are coming from, and I have forwarded the link to Netgear folks. I believe it's an error in the techspecs.
That said, do you still want to work on the performance problem?
I suggest the next step is to confirm the speed drop is wifi-only by testing with a wired ethernet device.
Assuming that is confirmed, I'd then do a factory reset on the gateway, and reconfigure it from scratch. You probably should document all your settings first. But don't save the config and restore it after the reset - sometimes the settings get corrupted after a firmware upgrade.
- William10aMar 03, 2017Master
Reading fact sheet closer I see that the problem it only shows that the people who write the product sheets are only human they were off by one line I guess that happens now and then when a company sales different standards with n as the old stand and ac as the most used standard on new routers.
