crossroads
Mar 08, 2017Aspirant
no wi-fi connections found
Wi-fi not doesnt have a valid IP configuration.....error message from my laptop. all other devices in my house work.
- Mar 08, 2017
It seems to be working now. It was a simple fix of changing the power option to "maximum performance" and restarting my computer. I will see if this takes care of the problem. Thank you for your help.
Mar 08, 2017Guru - Experienced User
Please give us the router model and the firmware it is running.
Though this sounds more like a PC issue than a router issue. Can you give us the exact wording of the error message (a screen shot would be best).
crossroads
N600 WiFi Cable Modem router
Model #C3700
The exact message: Wi-Fi doesn't have a valid IP Configuration
