crossroads
Mar 08, 2017Aspirant
no wi-fi connections found
Wi-fi not doesnt have a valid IP configuration.....error message from my laptop. all other devices in my house work.
- Mar 08, 2017
It seems to be working now. It was a simple fix of changing the power option to "maximum performance" and restarting my computer. I will see if this takes care of the problem. Thank you for your help.
Mar 08, 2017Guru - Experienced User
Please give us the router model and the firmware it is running.
Though this sounds more like a PC issue than a router issue. Can you give us the exact wording of the error message (a screen shot would be best).
crossroads
Also:
Problem with wireless adapter or access point
Wi-Fi doesn't have a valid IP configuration
- StephenBMar 08, 2017Guru - Experienced User
Did you try connecting over ethernet, and making sure that worked?
Also, what version of windows, and what is the wifi adapter model in the PC?
- crossroadsMar 08, 2017Aspirant
windows 10..I have no idea where to find the wifi adapter model in the PC. And I don't know how to connect over the ethernet
You connect over ethernet by connecting an ethernet cable between the PC and the router.
Use one of the ways in this link to open the windows device manager: http://www.isunshare.com/windows-10/7-ways-to-access-device-manager-in-windows-10.html Once that is running, look at the network adapter section. The wifi adapter will be in there.
Here's one thing you can try: https://www.youtube.com/watch?v=CJQOtXU4gJQ
