crossroads
Mar 08, 2017Aspirant
no wi-fi connections found
Wi-fi not doesnt have a valid IP configuration.....error message from my laptop. all other devices in my house work.
- Mar 08, 2017
It seems to be working now. It was a simple fix of changing the power option to "maximum performance" and restarting my computer. I will see if this takes care of the problem. Thank you for your help.
Mar 08, 2017Guru - Experienced User
You connect over ethernet by connecting an ethernet cable between the PC and the router.
Use one of the ways in this link to open the windows device manager: http://www.isunshare.com/windows-10/7-ways-to-access-device-manager-in-windows-10.html Once that is running, look at the network adapter section. The wifi adapter will be in there.
Here's one thing you can try: https://www.youtube.com/watch?v=CJQOtXU4gJQ
crossroads
