Bgbdwlf123
Oct 10, 2020Follower
No wireless connection but hardwire connection works
I have no wireless connection but I have hard wire connection the network does not show up on any device I own it used to but now it does not please advise?
Oct 10, 2020Guru - Experienced User
Maybe we should start off with what you have?
What router/router-modem is it? you didn't put a model.
Did the wifi on/off button get pushed? push and hold it for 2 seconds if you have on.
Otherwise you can go to netgear.com/support/ type in your model number. It'll take you to manuals, firmware, and guides that can help.
