Darienmen100
Jul 09, 2016Follower
Not able to connect to 5GHZ connection C6300
Earlier today the connection to my 5GHZ disappeared. I have turned it off and back on and it is now showing as a avalibale network. But when I try and connect it just says cannot connect. Any steps t...
DarrenM
Jul 15, 2016Sr. NETGEAR Moderator
Hello Darienmen100
Have you told you device that you are trying to connect with to forget the network then try to connect to it again.
DarrrenM
