umishrikotkar
Jul 11, 2017Tutor
Not able to login to N450 router admin
I am not able to login to admin page using the default id password. I am already logged in to same wifi network. I get bellow message- Error Code: INET_E_RESOURCE_NOT_FOUND ...
umishrikotkar
Jul 12, 2017Tutor
Encountered same issue with this link
vkdelta
Jul 12, 2017NETGEAR Employee Retired
what is the issue? I dont see any screenshot
- umishrikotkarJul 13, 2017Tutor
It is the same screen print as earlier with below message. I had attached in my earlier reply. Attaching it again.
Hmmm...can’t reach this page Try this
- This website might be marked as work-related by your organization. Try to access this link in a new Microsoft Edge window outside of Windows Defender Application Guard.
- Make sure you’ve got the right web address: http://192.168.100.1
- Search for "http://192.168.100.1" on Bing
- Refresh the page
This website could not be found.
- vkdeltaJul 13, 2017NETGEAR Employee Retired
can you please check with other Browser (chrome/firefox)?
looks like windows10 has some problems related to Edge/IE browser in latest update.
https://ugetfix.com/ask/how-to-fix-inet_e_resource_not_found-error-on-windows-10/
I get these messages in Chrome and Firefox.
Chrome
This site can’t be reached
192.168.0.1Â took too long to respond.
- Did you mean http://192-168-0-1.us/?
ERR_CONNECTION_TIMED_OUT==================================================================and below message in FIREFOXThe connection has timed out
The server at 192.168.0.1 is taking too long to respond.
The site could be temporarily unavailable or too busy. Try again in a few moments.
If you are unable to load any pages, check your computer’s network connection.
If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the Web. - umishrikotkarJul 13, 2017Tutor
I get below mesages on Chrome and Firefox
Chrome
Your connection was interrupted
A network change was detected.
ERR_NETWORK_CHANGEDFirefoxThe connection has timed out
If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the Web. - vkdeltaJul 13, 2017NETGEAR Employee Retired
can you ping 192.168.0.1?
can you ping 192.168.100.1?
please do ipconfig/all and provide information.
- umishrikotkarJul 14, 2017Tutor
I was able to ping and below is the result of all 3.
>ping 192.168.0.1
Pinging 192.168.0.1 with 32 bytes of data
Reply from 192.168.0.1: bytes=32 time=1ms TTL=64
Reply from 192.168.0.1: bytes=32 time=2ms TTL=64
Reply from 192.168.0.1: bytes=32 time=2ms TTL=64Ping statistics for 192.168.0.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 2ms, Average = 1ms====================================================
ping 192.168.100.1
Pinging 192.168.100.1 with 32 bytes of data
Reply from 192.168.100.1: bytes=32 time=2ms TTL=63
Reply from 192.168.100.1: bytes=32 time=1ms TTL=63
Reply from 192.168.100.1: bytes=32 time=1ms TTL=63Ping statistics for 192.168.100.1:
Minimum = 1ms, Maximum = 2ms, Average = 1ms=======================================================================
>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : USMD5000
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : NoWireless LAN adapter Local Area Connection* 3:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
Physical Address. . . . . . . . . : B8-81-98-E5-A8-6D
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : YesWireless LAN adapter Wi-Fi 2:
Description . . . . . . . . . . . : Intel(R) Dual Band Wireless-AC 3165 #2
Physical Address. . . . . . . . . : B8-81-98-E5-A8-6C
IPv6 Address. . . . . . . . . . . : 2601:246:c500:2b20:b143:539a:b176:837b(Preferred)
IPv6 Address. . . . . . . . . . . : 2601:246:c500:2b20:ba81:98ff:fee5:a86c(Preferred)
Lease Obtained. . . . . . . . . . : Thursday, July 13, 2017 8:34:42 PM
Lease Expires . . . . . . . . . . : Thursday, July 13, 2017 9:52:32 PM
Temporary IPv6 Address. . . . . . : 2601:246:c500:2b20:1c67:7ae9:98e1:f94b(Preferred)
Link-local IPv6 Address . . . . . : fe80::b143:539a:b176:837b%7(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.10(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Thursday, July 13, 2017 8:34:48 PM
Lease Expires . . . . . . . . . . : Thursday, July 13, 2017 10:44:48 PM
Default Gateway . . . . . . . . . : fe80::eafc:afff:fee9:fd93%7
192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DHCPv6 IAID . . . . . . . . . . . : 95977880
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-20-DF-95-C8-B8-81-98-E5-A8-6C
DNS Servers . . . . . . . . . . . : 2001:558:feed::1
2001:558:feed::2
192.168.0.1
NetBIOS over Tcpip. . . . . . . . : EnabledEthernet adapter Bluetooth Network Connection 2:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network) #2
Physical Address. . . . . . . . . : B8-81-98-E5-A8-70
Autoconfiguration Enabled . . . . : YesTunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:6ab8:30de:32c2:bc47:1573(Preferred)
Link-local IPv6 Address . . . . . : fe80::30de:32c2:bc47:1573%5(Preferred)
DHCPv6 IAID . . . . . . . . . . . : 369098752
NetBIOS over Tcpip. . . . . . . . : Disabled - antinodeJul 14, 2017Guru
As I read this, you can access the Web in general, but not the Web
interface of the router itself. Right?
Have you power-cycled the router? I know nothing about the
CG3000Dv2, but there are firmware bugs on at at least one other router
model which can kill the router's Web server, which could explain this
sort of behavior. With those bugs, restarting the router restarts the
router's Web server, restoring normal operation. Until, that is, the
user hits the wrong button on a management Web page, and again kills the
router's Web server. But you should be able to get a Web page instead
of a browser error before things fail (again?). - umishrikotkarJul 14, 2017Tutor
Yes i am able connect to internet in general but just not the router admin site. i have disconnected and re started the router at least 3-4 times.
