qbpals
Apr 06, 2016Aspirant
Not all DHCP Reservations are displayed in Safari or FireFox
As listed my cable modem is the C7000-100NAS AC1900. I've added about 9 DHCP reservations, mostly for WiFi connected devices that either don't have a way to set a Static IP or they are laptops/iPads that I don't want to setup as using Static IPs as they move from location to location.
The problem is now I want to DELETE certain rservations. However the table on the C7000's Advanced/Setup/LAN Setup shows me only 4 reservations. Any of these 4 I could click the radio button and "Delete."
THe only place I see all 9 reservations is if I first clicke "Add" and then that displays a complete table. However in that table I cannot Delete any of the entries.
I tried selecting one and removing the vital info (MAC and setting IP to 192.168.0.0) but then I get an error message.
How can I view the complete DHCP Reservation list so I can delete reservations.
(edit to add:) Firmware version is v1.01.15
Note: I've also used the current NetGear Genie Mac application but it does not appear to hand the DHCP Reservations at all.
thank you
qb
Ok, get into the Address Reservation page.
Click Add button. It will show all the list and no delete button correct?
Select the one you want to be deleted and click Add button.
After clicking on that Add button, you will be redirected on the Address Reservation page where you can now click Delete?
- qbpalsAspirant
ElaineM - I'm not sure I follow.
If I add some new (or made up) MAC it takes me to the page that shows the green ADD button and two purple ones (Cancel and Refresh). In the ADD page I can click on radio buttons next to each reservation but there is no DELEˇE function on that page.
So - I ee the longer list of reservations when on the ADD screen but see no way to do a DELETE there.
If I actually add a MAC and click ADD - I return one page back to the list of address reservations but it again shows me only 4 or my 9 reservations. I see no way to SCROLL or Expand that list to show more or to show another "page" of reservations. Nor can I click the column labels in hopes of resorting the table and making those I need to delete show up.
thank you
- ElaineMNETGEAR Employee Retired
